Repower my coupe..........maybe?
From Seattle ,WA.
so after a few years and a few thousand miles I'm toying with the idea of more power / bigger motor. The A15 I built is pretty decent but I feel like it needs more power.I believe Ernie thinks KA is the way to go and as he's managed to burn thru a few motors and a multiple swaps this seems like a decent way to go but am wondering about possible motors as well. Nt really interested in turbo as seems like it always eats tons of space in a 1200 engine bay, would also possibly entertain an automatic vs. a stick if enough power can be had out of a mildly built KA or some such.
A manual trans swap would probably be easier as its already a stick, pedals, etc...
What did KA's come in that were rear wheel drive - frontiers, Exterra's, 240's ??
Just at the thinking stage now and it may never get beyond that but I am tempted so any thoughts are appreciated!
E
Posted on: 2014/12/30 2:14
Re: Repower my coupe..........maybe?
A stock KA24DE from 240SX is the way to go: 2.4 liters and 156 hp. A built KA has problems.
Another choice is the SR20DE, if you like high-revving it. They can be reliably built to 150 HP or even 175 HP.
Posted on: 2014/12/30 4:21
From Seattle ,WA.
would an auto trans fit the 1200 tunnel? my thought is stock for reliability and decent power with about 70% more than my A15) w/an auto will make a nice daily.
what about rear end - I assume stock 145 pumpkin wont be strong enough - will 150 from a 210 do it?
Posted on: 2014/12/30 15:23
To fit the 71-series automatic, Datsun fitted a larger tunnel to the auto 1200. You can fit this tunnel to any 1200 rather easily, and it seems to be identical to early B210 and 610 tunnels (pre-catalytic convertor). See Tunnel.
With more torque than a stock A14, it is recommended to fit a larger differential. The H150 can only handle a little more torque. It is recommended to fit an H165 for use with a 2.4 liter, or with a turbo 1.8. They cheap swap is an H190 out of a Datsun 320 pickup, it is however it little narrower than than the 1200 rear axle assembly.
Posted on: 2014/12/31 3:37
