Anyone know where to get the weather stripping for the back swing-ou side windows of a 2 door sedan?
Not too shy to talk
From Los Angeles, CA
Been looking all over the place and can't seem to find em! Anyone know where to get them?
Posted on: 2014/10/24 9:08
Re: Anyone know where to get the weather stripping for the back swing-ou side windows of a 2 door sedan?
From Perth WA AUS
Its similar to a standard door seal with a pinch weld thingy attached to the rubber seal.
I got mine off a Toyota Hiace van, Clarke rubber used to sell it by the meter but not sure if they do now.
Best get a sample and test fit first.
EDIT: Maybe add some info to your profile as to where in the world you are located, that might help :)
Posted on: 2014/10/24 10:26
Datsun 1200 2Dr sedan.
1979-1982 Datsun B310 weatherstripping can be used for B110 2-dr sedan rear side window. It's almost perfect, but about 1 inch too short for the B110. Just trim a bit of it off when fitting to the B110.
Original B110 is two piece: A welt, and a rubber weatherstrip glued to the welt.
Generic Welt
Posted on: 2014/10/24 11:27
From Castro Valley,CA USA
Trimloc.com
Trim seal products
Posted on: 2014/10/25 6:10
The trim-loc seal that I used was like this with a 3/4" bulb.
http://www.mcmaster.com/#bulb-seals/=v9jimx
Select EDGE-GRIP SEALS,Style #2 or #3 with a 3/4" bulb
Confirm how thick the edge is that this clips to.
Something like this...
http://www.mcmaster.com/#1120a563/=v9jlwb
Posted on: 2014/12/31 17:52
