« 1 ... 11 12 13 (14) 15 16 17 ... 57 »
Re: Datsunbeginner becomes an expert - Vanilla Ice ute build USA
The wear marks on the flange are typical adjustments made to ensure the manifold sits well with the extractors. The GX twin side-draft manifold is very similar, if not the same casting to the JTS manifolds, quality is good with a nice solid bridge to join the pairs of runners, the provision of four blind bosses, one on each runner can be plumbed for vacuum reference. I prefer a manifold with an integrated throttle shaft mount as I find those threaded components holding the throttle bar to be a PITA, sometimes older units have sloppy threads and I have had my entire throttle assembly 'lift' before, causing much drama while tearing out onto a highway throttling a mongrel race engine.
The small collar with a tightening nut is a locking collar to stop the throttle shaft moving forth and aft (looking from drivers position). There are typically two of these, or sometimes one collar and an 'e-clip'. Looks to have a circular throttle bar which can be problematic when it is of a small diameter, over-springing the throttle return can lead to constant slipping of the throttle arms - this symptom is typically what creates the myth that 'side-drafts continuously need tuning'. This is not the case if set-up properly using the appropriate diameter rod.
$150.00 is a good purchase to include most of the linkages. A good starting base.
Posted on: 2014/10/8 21:43
Thanks Chris for the comments.
The grind/wear marks on the flange looked to me like they were done deliberately as you suggested for fitting extractors.
The linkage assembly seems heavily used. I might consider buying a new linkage kit just to have a setup that is solid. I acknowledge your comments how a worn setup can cause issues with the throttle and the running of the sidedraft carbs.
Do you have a linkage kit that you would suggest for this setup new....where to buy?
I suppose also that I will need those spacers that go between the manifold and the carbs, and also trumpets or filters for the carbs too.
Thanks for the help.
Posted on: 2014/10/11 12:24
Hi,
The linkages setup in my opinion is best made from quality parts sourced from hardware suppliers, the kits offered on-line are just not that great unless you can find someone with some real savvy, here is where I buy all my carb parts:
Dellorto UK
Quality linkage rod ends can be found at relevant hardware outlets, CBC sell good units.
As for spacers I recommend these, the thicker the better. Remember you may need longer manifold studs to accommodate the thick spacers.
Phenolic Spacer 1/4" thick
Phenolic Spacer 1/2" thick [reccomended]
Posted on: 2014/10/11 22:21
So much bling
jpg  IMG_2014111228737.jpg (50.58 KB)
13419_546351670a75e.jpg 800X600 px
Posted on: 2014/11/12 12:24
Do they make those for men? ??
I guess you can do your make up in It. What's the bracket for?
Posted on: 2014/11/12 20:53
I believe it was welded on to allow for a center pull throttle cable setup. Which will suit my twin carbs juuuuuust nice. Hopefully.
Posted on: 2014/11/13 8:15
Choices: * Use stock 1200 coil with stock ballast resistor or * Fit EI coil and remove ballast resistor
The latter will make it a high-energy system, for better burning, less missfire. Then you can change the spark plugs to .13 mm type for the ultimate system.
Reminder
Posted on: 2014/12/30 10:16
Just finished my build!
jpg  IMG_2015010139188.jpg (52.96 KB)
13419_54a52dbfc1b38.jpg 800X600 px
jpg  IMG_2015010123759.jpg (57.85 KB)
13419_54a52dd3b8484.jpg 800X600 px
Posted on: 2015/1/1 11:22
nice color
Posted on: 2015/1/1 11:33
WHOA, you even converted it to a LWB.
Posted on: 2015/1/2 2:17
