Are these from A14T ?
Hi, i have the chance to buy these carbs.... seller says they came from an A14 japan import....
Look correct to me based on tech wiki but before i hand over hard earned cash could someone pass comment ?
I plan to put them on my A14, then maybe later swap to an A16....
Price is 560 AUS or 456 usd
jpg  1421135048233-lr.jpg (122.06 KB)
16289_54b4dcb1481d7.jpg 531X480 px
jpg  1421135056951-lr.jpg (155.63 KB)
16289_54b4dcd084f2e.jpg 640X480 px
jpg  1421135258578-lr.jpg (88.68 KB)
16289_54b4dcec47424.jpg 457X640 px
jpg  1421135270098-lr.jpg (125.31 KB)
16289_54b4dcfba059d.jpg 476X640 px
Posted on: 2015/1/13 8:53
Re: Are these from A14T ?
They look like a flat top A12GX variant.
Posted on: 2015/1/13 9:59
yes, looking more closely at the wiki, these have an oval mounting flange (carb to manifold) where the A14T ones have a square flange.
If these are A12GX ones, would they be ok on my A14 and upto A16 ?
Edit... found this link through the wiki, it looks like the same set-up and the guy says theyre for an A15...
http://jaw.iinet.net.au/cars/120y/hitachis.html
Posted on: 2015/1/13 10:14
Those are not GX which was strictly dome top.
They are A12T and so the manifold is too big for an A14.
The carbs will work on any engine. The manifold is the critical part.
Posted on: 2015/1/13 12:32
Right as usual DD..if you look at the casting on the manifold flange its the larger oval shape..
is there no way for it to fit ? would it bolt up, and maybe the Cyl head could be ported ?
Not that i want to go to that sort of effort....
jpg  bigsmall intake.jpg (45.84 KB)
16289_54b51f530ef84.jpg 480X480 px
Posted on: 2015/1/13 13:36
Yes, you can "port match" the cylinder head, by grinding the ports out to match the manifold.
The nice thing about those carbs is
* They've been de-smogged
* Still have the idle mixture system, for precision idle adjustment
Posted on: 2015/1/13 22:26
Ok I'm going to get them. Bit of work to port the H89 head I'll be putting them on to but I hope it will be worth it.
Thanks for your help , BTW how can you tell they're desmogged?
Posted on: 2015/1/14 0:38
Stock A12T (Datsun B210 twin carb) setup has a lot of emissions equipment.
Posted on: 2015/1/14 1:05
From Kelmscott Western Australia
Heres the a12s on a A14
jpg  FullSizeRender.jpg (40.09 KB)
13822_54b6332fd36f6.jpg 320X240 px
jpg  FullSizeRender-1.jpg (41.27 KB)
13822_54b6333c34884.jpg 320X240 px
Posted on: 2015/1/14 9:13
looks good,
looks like you are not using the water cooling ?
Whats the performance like ?
Were the standard needles etc ok or did you have to change them ?
For the air filters, do the equivalent British SU ones fit ?
Posted on: 2015/1/14 9:41
