« 1 (2)
Re: S12 5sp gearbox
Difference in length between Stumpy and S13 gearbox
S13 gearbox fitted into 1200
Posted on: 2015/1/16 12:37
Re: S12 5sp gearbox
From New zealand
Are you running the Maddat fitting kit ? How does the box shift at hight rpm ......and did you end up fitting the speedo cable to the stumpy box ?
Posted on: 2015/1/18 8:14
Re: S12 5sp gearbox
From New zealand
Dam that stumpy box is much shorter !!! the photo with the box fiitted in the ute is that the standard 1200 box tunnel ?
Posted on: 2015/1/18 8:18
« 1 (2)
