Hitachi DCH problem
Hi, I have a problem with the Hitachi DCH carb.
Not runnig the engine some hours, and the fuel flow from the floating house trough idle hole in the inlet manifold. The anti-diesel valve work, float level is correct. What is the problem? You had this problem? What was the solution?
Thank You, and sorry my bad language knowledge.
Posted on: 2015/2/1 15:36
Re: Hitachi DCH problem
Unusual problem because it is normally caused by fuel level overflow.
Air bleed should prevent fuel siphoning through idle port, so inspect top of carburetor for dirt which may be blocking the air jet.
Posted on: 2015/2/2 4:12
