(1) 2 3 4 5 »
Anyone converted to electronic ignition?
From Townsville NQ
Crane have a kit to convert points to high energy ignition, check out Crane under --> Rocket Industriesand look at XR3000 points to electronic kits. I believe Martin Donnon used one on his 1200 ute "The Gimp" about 5yrs ago in a Hot4s mag.
Also here's the Crane link --> Crane Aust
Anyone have one?
Posted on: 2004/6/3 0:52
Re: Anyone converted to electronic ignition?
From Townsville NQ
Supercheap have them for $365! you just need an electronic coil from any solid state car then & away you go!
Posted on: 2004/6/3 1:37
From Sydney Australia
Also if $365 sounnds a little steep,
Thundercords in Sydney have a Pertronix kit for $270 including GST.
Try this site
http://www.magnecor.com.au
Posted on: 2004/6/3 2:07
From Brisbane
I heard Petronix is very easy to install
but still very expensive
Posted on: 2004/6/3 2:31
From Townsville NQ
is it actually high energy though or still 7v? I want more spark energy to suit the blower, the Crane one is full 12v setup, not just points removal.
Posted on: 2004/6/3 2:53
The 'points eliminator' Pertronix system is often on eBay for about $75 US, shipping to AU would only be a few bucks.
Eliminating the points is 99% worthwhile. Unless you are running a turbo or supercharger, or super-high compression (12:1 or more?), would the high-energy really make that much difference?
Posted on: 2004/6/3 6:12
From Townsville NQ
Refer above where I said I was using a blower.
don't get me wrong, I'd use petronix if it's high energy cause it's cheaper, but if it's not for approx $100 more I'll get the high energy one thanks.
Back to my main point, is anyone here using one?
Posted on: 2004/6/3 6:55
Quite a regular
From Perth Oz
I put a Jaycar high energy ignition system on mine. makes cold starts HEAPS easier but not designed for high performance applications......
$60 by the way
Posted on: 2004/6/3 7:11
There is information on these conversion kits at www.warehouseautoparts.com
It says it delivers twice the voltage at the sparkplugs. Would this be a high energy system ?
Posted on: 2004/6/3 7:14
From Castro Valley,CA USA
pertronix
I don't think its a high output ignition. I don't know about the new ones, but the old ones could not drive a high energy coil or they would burn out. I use mine to trigger an MSD 6AL.
Posted on: 2004/6/3 7:40
(1) 2 3 4 5 »
