« 1 2 3 (4)
Re: L16 twin su into a15
as i noticed, the jetting, needle, bore(38mm) all looks same for both carburetors. ill give a try on flat top carb this weekend.
Posted on: 2015/2/24 14:47
Yes, both carbs are 38mm
L16 and A12 require 12:1 to 14:1 air-fuel ratio so the jet needles are similar. The biggest difference is the dome spring, it is heavier in the L-series carburetors. That affects the acceleration mixture.
Posted on: 2015/2/24 21:37
« 1 2 3 (4)
