Engine plate
From Las Vegas NV
I'm swapping from auto to manual with a 60 transmission my question is do I need the metal plate between the engine and trans
Posted on: 2015/2/24 22:19
Re: Engine plate
Yes
Posted on: 2015/2/24 22:31
Re: Engine plate
From Las Vegas NV
Thanks for the info
Posted on: 2015/2/25 0:09
Re: Engine plate
It is a matched set:
* plate
* transmission type
* flywheel
* throwout bearing sleeve
If these all came from the donor car you will be alright.
If you mix-n-match, it becomes a problem. For example, all the above from an A14-powered B210 but using an A12 flywheel. In that case better leave off the plate.
Posted on: 2015/2/25 0:37
Re: Engine plate
From Las Vegas NV
I have a A12 with a auto trans , I got a donor car A12 with a 4 speed wich didn't have the plate , but I got a 60 series trans from another member , so I wanto install the 60 series into the A12 do I need that plate ? For clutch and flywheel is going to be for A12 engine
Posted on: 2015/2/25 4:42
Re: Engine plate
Which clutch is used doesn't matter on the A-series.
* plate
* transmission type
* flywheel
I would use the 1200 4-speed as it is faster/lighter. And you know its a matched set with the other parts. But if it is worn out or something the 60 is good. Just needs an adapter bracket to bolt in and figure out what to do about the reverse light switch.
A12 flywheel and 60 transmission is a short combo.
* if you have the long 34 mm Release Sleeve, use the engine plate
* if you have the short 29.5mm Release Sleeve, leave the plate off
Posted on: 2015/2/25 7:45
Edited by ddgonzal on 2015/2/25 8:03:18
Re: Engine plate
From Melbourne, Australia
Wish I readread this before...
I found a horrible combo...
A15 swapping auto to manual 60 series smooth case 4 spd
No engine plate plus what I assume is a van flywheel that had been lightened, its thicker behind the ring gear than an a12 flywheel.
The car wouldnt turn over. After investigation the flywheel is actually jammed almost solidly into the bellhousing
Haven't pulled the box back out yet, still crying, but I will be checking the throwout carrier size etc when I do
If anyone has an engine plate I would be keen to buy it!
Posted on: 2015/10/11 12:45
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Engine plate
Hmmm, haven't heard of that problem before, even though A14/A15 flywheels are thicker than A12 flywheels. By any chance is the automatic crank spacer still attached?
Posted on: 2015/10/11 13:40
Re: Engine plate
fark... maybe! lol
will check someday this week when i get inspired to pull the box out (although it should be sitting with the ring gear etc if i took it out, that was a couple of weeks ago, so im not confident now)
Posted on: 2015/10/11 23:50
1200 Coupe Rallycar
Re: Engine plate
i just had a look at a pic of the spacer, i must have removed it because i changed the rear main seal, it looks as though you could not change the seal without removing the spacer
Posted on: 2015/10/11 23:56
1200 Coupe Rallycar
