« 1 (2)
Re: Cortina webber - does it fit a 120y?
From Hobart Tasmania AUS
does any know if a webber 32/36 can go on a 1000 manifold? Or is it easy to put a 1200 manifold on A10 block.. has anyone done either of these?
Posted on: 2004/6/3 3:10
1968 1000 Wagon
1967 1000 2 Door Sedan (A12)
1969 1000 4 Door Sedan
1968 1000 4 Door Sedan (parts car)
1964 Toyota Coaster Bus
From Perth W.A
i used the throittle linkage from the stock hitachi carb Carb Linkage pic
i bought a webber adaptor plate that fits the a-series engines from my local auto parts store and it said a series datsun it was a redline manifold.
i found the easiest way to get the fuel lines to do the right thing is to get an aftermarket fuel filter with the changeable ends say one of the anodised ones or glass ones so you can choose the line size for each end and have the in for fuel 1/4 and the out 5/16 and you will need a length of 5/16 hose aswell and maybe a couple fuel line clamps for the bigger hose. i'm yet to run mine cos i'm missing the idle mixture screw but as soon as i get mine it should be fine. and you shouldn't need any more than $150- 180, that includes rebuild kit carb from wreckers and filter hose and clamps. and also go to webber base settings
hope this helps
Posted on: 2004/6/3 3:57
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Brisbane
How about the bracket that holds the accelerator cable?
I bolted mine on the manifold and is very stable
Posted on: 2004/6/3 4:13
From Perth W.A
i have just used the metal loop on the top of my rocker cover to do that i don't know if this will still work but i guess it will
Posted on: 2004/6/3 4:53
120y Coupe
From Brisbane
I'll take a photo of my bracket this weekend
Posted on: 2004/6/3 5:19
Yes, the only "difficult" part of this is the cable bracket. I too used a loop of metal (aluminum, as it is easy to bend and drill three holes in it).
You can use the stock fuel pump, stock filter, stock inlet manifold. I bought a used carburetor that was from an L16 pickup, and used the stock jetting, which was close enough. I made the adapter plate. So I only spent a few bucks.
Posted on: 2004/6/3 6:08
From CHristchurch, New Zealand
Orsome guys. Thanks a lot for your help. I went to supa cheap auto spares today and they are gunna try and get a kit for me, But I think i'll take the advice and look aound for a smaller carb. Im also havn problems gettn a boss kit (they quoted $115! and Repco $100.00) Bugger that!
Posted on: 2004/6/3 10:02
From Tassie, Australia
What does $115 NZ equate to in AU? Around $103AUD? I take it the boss kit is coming from Australia? Should be about $80 new in Australia in Aussie dollars plus freight?
Posted on: 2004/6/3 13:19
« 1 (2)
