Driveshaft for a 71 UTE
From Las Vegas NV
Long story short , I have a 71 Datsun UTE somebody did a swap from manual to Auto, now I want to swap it back to manual , i got a driveshaft from a manual coupe but it looks to short be cause it leaks gear oil from the back of the transmission, does the ute have a different driveshaft? Also if it is different which US model have a similar set up?
Posted on: 2015/2/28 6:04
Re: Driveshaft for a 71 UTE
Wait, you have a ute?
Any ute driveshaft will work, 1971-1994. It can't be from a coupe or sedan as those use a smaller diff flange. Possibly a 1975-1978 B210 shaft may work but only from a 4-speed B210. Possible a 1979-1982 Datsun 210 4/5-spd car. They have the right flange, but the length may or may not be right.
Posted on: 2015/2/28 6:30
Hmm .
Maybe they swapped more parts because a coupe tailshaft should be longer.
* Coupe/sedan: 1138 mm (u-joint to u-joint)
Is your ute a B120 or a GB120 as listed on the aluminum plate in engine bay?
Posted on: 2015/2/28 6:39
From Las Vegas NV
Is a B120 , the shaft from the coupe it fits and bolts on but is to short
Posted on: 2015/2/28 7:16
With the original ute rear axle, a coupe driveshaft won't bolt on. It sounds like someone swapped rear ends. That's good as the original, while tough, is heavier.
So possibly the engine is too far forward. It should only be 25cm between firewall and back of head.
Or maybe the leak is because a bad rear seal.
Got pictures of your 1200 Pickup?
Posted on: 2015/2/28 7:26
From Las Vegas NV
Can't upload pics , all the pictures are to big to upload , I can send it to you by email or on Facebook
Posted on: 2015/3/1 2:10
Yes, we can only upload 1megapixel here.
You can link the photos which are on Facebook here. Right-click in Facebook and get the location/properties, then here click the Image icon and paste in the URL
Click Reply to get the Image button.
Posted on: 2015/3/1 2:31
From Central coast NSW
The seal size is 30mm yoke x 45mm extension housingx 7mm deep or I put in a 10mm it was all they had in stock, any bearing and seal shop should have one for u to try it will only be 5-7 big ones.
Posted on: 2015/3/1 14:16
Denis is this the one you bought?
Posted on: 2015/3/2 4:33
From Bendigo, Victoria
I have owned 2 71 model utes and both had H145 in them. 4.11 ratio.
Posted on: 2015/3/2 9:03
