wanted mild cam suit a12, a12 flywheel and good clutch
From Adelaide, Australia
Hey guys just chasing a very mild cam, a12 flywheel and a decent clutch. Something to suit turbo a12 application. Please pm me with details thanx :)
Posted on: 2015/3/3 12:53
Edited by Matto1kUte on 2015/3/7 3:22:16
Re: wanted mild cam suit a12, a12 flywheel and good clutch
Do the stock a15 vanettes have a better clutch? Should I go for new vanette one? Sorry budget is low :\
Posted on: 2015/3/10 11:28
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Kelmscott Western Australia
A new clutch kit is only 70-80 buks its a clutchpro brand its a good brand
Posted on: 2015/3/10 12:04
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
You could use a Datsun 1000 camshaft. It is milder than an A12 cam.
Posted on: 2015/3/10 20:11
Re: good clutch
A15 clutch is heavier
Clamping Force
* B210 A12: 616 pounds
* B210 A13: 694 pounds
* B210 A14: 794 pounds
* B310 A12A: 573-684 pounds
* B310 14/A15: 739-849 pounds
As with Nissan, aftermarket clutches are heavier duty, requiring increased pedal effort. So aftermarket A12 clutch may be the same as the heavy A15 spec.
The most heavy-duty clutch from Nissan are:
* 30210-H5220 420KG (926 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE
* 30210-A1200 550KG (1213 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE
Posted on: 2015/3/10 20:18
Re: good clutch
Quite a regular
Pm sent
Posted on: 2015/3/10 21:52
K got a flywheel but after a heavy duty stock type clutch. Yea I'm not sure if a heavy duty is the same as a a15 type
Posted on: 2015/3/15 3:32
