LED Lighting!
Online
Saves power
Brighter
High Technology
Reference: see Bulbs
INSTRUMENT PANEL BULBS
RockAuto $5/pair
Philips 194 - 1W (replaces stock 1.5W or 1.7W bulbs). Type 194 is normally less bright than stock, but the LED version is supposed to be brighter???
These are T10 bulbs with a T5 base. W2.1x9.5d base (aka W2 or T5 base), known in USA as "Miniature Wedge" base. The T5 base fits into the Wedge socket.
Posted on: 2015/4/5 1:17
Edited by ddgonzal on 2015/4/5 1:44:52
Edited by ddgonzal on 2015/5/7 3:31:42
Re: LED Lighting!
Online
BRAKE LIGHTS
Quicker light-up for greater driving safety
Type 1157 23/8W (North America)
Rear Tail & Stop
RockAuto $11.21 pair
* Dorman 1157WSMD
* Philips 12836RED Vision LED (red for clear lense)
* Philips 12899RX2 X-treme Vision
Posted on: 2015/4/5 1:57
Re: LED Lighting!
Online
TURN SIGNAL BULBS
Load-independent Flasher
2-pin Electronic Flasher
Instrument Panel Turn Signal indicator
* 1.7 watt (ROUND GAUGE) Type 1445
* 3.4 watt (Square Gauge) Type 57
search for 1445 LED
FRONT COMBO LIGHT T/S BULB
* 23/8 watt North America Front park & T/S search for 1157 LED
* 12/5 watt Japan
REAR COMBO LIGHT
* 23 watt search for 1156 LED
* 21 watt
Posted on: 2015/4/5 2:16
Edited by ddgonzal on 2015/4/5 2:37:00
Edited by ddgonzal on 2015/4/5 2:45:00
Edited by ddgonzal on 2015/4/5 2:47:20
Edited by ddgonzal on 2015/5/7 5:12:05
Edited by ddgonzal on 2015/5/7 5:20:32
Edited by ddgonzal on 2015/5/7 5:43:36
Re: LED Lighting!
From Brisbane
You can also get leds for the interior dome light that are super bright. Make sure they are 5050 type - 24 -36 lights per board will fit.
http://m.ebay.com.au/itm/290996615963
Posted on: 2015/4/5 16:33
Re: LED Lighting!
Online
Thanks!
What bulb numbers do Aussie 1200s use?
Posted on: 2015/4/5 20:38
Re: LED Lighting!
I bought "T10" wedge bulb LED's for my dash instruments when I was there.
Posted on: 2015/4/5 23:12
Re: LED Lighting!
Online
Yes, Philips 194 is a brighter version of the type 161 used by Round Gauge dash. The Rectangle Dash also uses the T10 wedge socket.
Posted on: 2015/4/6 2:58
