Unidentified cable
From Sydney, Australia
Hi Guys,
I am new to this forum so apologies if I have posted this under an incorrect category.
I recently bought a datsun 1200 ute and would love to get it restored. I am not a mechanic but would love to learn about cars and hopefully with the help of this forum and google I one day will be able to get my ute ready :).
For a start, will some please be able to identify the attached parts for me? there is a strange cable that is not connected to anything, not sure what that cable is. It is coming from the firewall.
Will really appreciate any suggestion/comments.
Kind regards,
Ron
jpg  Capture.JPG (150.73 KB)
18758_5548072224bae.jpg 1187X716 px
Posted on: 2015/5/5 0:56
Edited by Avizhome on 2015/5/5 11:27:37
Re: Unidentified cable
Hi Ron, welcome to the club.
Unfortunately that is not a stock cable. So we don't know what it is.
Posted on: 2015/5/5 2:02
It looks to be coming out of the firewall where the clutch cable usually comes out of, but doesn't look like a clutch cable to me.
EDIT: I meant choke cable
Posted on: 2015/5/5 2:20
Edited by datsunbeginner on 2015/5/5 21:36:29
Hey Ron,
A and B are part of the Brake Master Cylinder and what you have labeled there are the front and rear fluid reservoirs.
C is your speedo cable
And the mystery cable is coming out of the hole in the firewall for the choke cable. I'm gonna take a guess that the previous owner had that hooked up until he rebuilt the carbie and then didn't bother hooking it back up again.
Welcome!
Posted on: 2015/5/5 3:19
Thanks Guys!
Really appreciate all your response. Will keep you all posted with the restore updates.
Posted on: 2015/5/5 5:35
Correction:
* C is the clutch cable
* Speedo cable is just behind the clutch cable
Posted on: 2015/5/5 6:09
My 1200 had a wire coming out of that exact same spot
It was for the aftermarket tachometer, wire lead to Coil. But your cable goes somewhere else.
Late utes had an auto choke, so no cable in that hole. It was just a plug. The choke wire came out of the engine harness.
Posted on: 2015/5/5 6:20
My coupe has a manual choke which comes out of that hole, but I suppose it could have different uses depending on the year/model?
Posted on: 2015/5/5 7:23
Yes.
* Early 1200s had a manual choke, so cable comes out that hole.
* Late 1200 didn't have a manual choke, so that hole is plugged.
In the photo it appears to be an electrical wire instead of a cable.
It also appears to be a late 1200 judging by the coil on the firewall.
Posted on: 2015/5/5 7:39
Hi guys,
Yes, it is a 1977 model.
Thanks
Posted on: 2015/5/5 8:57
