EFI or Carby
From Sydney, Australia
Hi Guys,
I am pretty sure this post has been discussed before. My appologies for reposting, was not able to find it.
I am restoring my 1200 ute with a stock A12 engine. Looking for some advice with EFI conversion. Is it expensive? is it simple? and is it worth doing it? EFI would probably be better with fuel but is it worth it?
Thanks again for all your advice/suggestion.
Kind regards,
Ron
Posted on: 2015/6/4 0:45
Re: EFI or Carby
Well if your goal is restoration then it must be carbureted, as EFI was never offered on the A12.
If you don't mind a modified vehicle, then EFI is cheap and easy (about $2500 + $500 for tuning)
Posted on: 2015/6/4 1:35
Re: EFI or Carby
Thanks DD, can A12 be modified for EFI? is it an easy modification? Has anyone in this forum tried doing it?
Posted on: 2015/6/4 1:55
Re: EFI or Carby
No mods are needed for EFI, just bolt the stuff on.
Then your ute will no longer be restored, which means returned to original condition.
Posted on: 2015/6/4 4:40
Re: EFI or Carby
Get this:
EFI Australia A12 manifold
Two of these:
EFI Hardware Australia
$260 manifold
2x $515 throttle bodies
4x $110 injector
$220 fuel rail kit
throttle linkage
fuel pump
return line fuel tank modification
surge tank
EFI-rated fuel hoses and clamps
EFI fuel filter
O2 sensor kit
TPS
MAP sensor
IAT sensor
Coolant temp sensor
Oil temp sensor
ECU $600 to $1500 - Haltech or Wolf or MegaSquirt, etc.
wiring harness
Posted on: 2015/6/4 6:22
Re: EFI or Carby
thanks dd, really appreciate your help.
Posted on: 2015/6/4 6:25
Re: EFI or Carby
Posted on: 2015/6/4 9:59
Re: EFI or Carby
That one is a work-in-progress, not available yet or is it?
Posted on: 2015/6/4 10:23
Re: EFI or Carby
It can be diy. He's tuned to na already. Just turbo to go
Posted on: 2015/6/4 10:55
Re: EFI or Carby
From Sydney NSW
Wasn't there someone putting itbs off a 4AGE on one some where
Posted on: 2015/6/11 2:07
There maybe faster ways to go...
But I'm never in a rush
