Ca18det timing questions
From Goulburn NSW
Hi guys can anyone explain in detail how to set everything for my ca18det timing,this is for my own knowledge base and will be used to talk to my engine builder to make sure its set up wright for ignition.Ok so do it set number one cylinder to TDC (which is cylinder one,very front?)then set the cam gears to the marks on the cam gear backing plate(either side of cam gears)then put on my timing belt.
Posted on: 2015/6/7 11:19
Re: Ca18det timing questions
From Brisbane
This link should help. http://www.driftopia.com/2008/09/10/c ... l-part-1-the-factory-way/
changing my timing belt now and using this guide.
Posted on: 2015/6/8 1:36
From Goulburn NSW
Hi oda,thats perfect thank u.
Posted on: 2015/6/8 2:23
From Brisbane
also from that link the ca18det FSM download from first paragragh, print out pagers 63-67
Posted on: 2015/6/8 2:39
