rotor size for brakes up grade
From Nyngan, nsw Australia
purchased S13 calipers (non turbo) not sure if there is a differences between standard and turbo....anyways are the rotors 250mm or 280mm I need for the job!
Posted on: 2015/6/30 5:25
living is good,.....
Re: rotor size for brakes up grade
Either size can be fitted to the 1200. See S13 Brakes.
Posted on: 2015/6/30 5:28
ok thanks, on calliper said: 29W, B43, H3 not sure if means anything...and on old pads BM1462
Posted on: 2015/6/30 5:40
BM1462 appears to be the pad formula, doesn't tell us what caliper it is. Got a pic?
Best to get the calipers matching the rotors:
280mm rotor + 280 sumitomo caliper
250mm rotor + 250 caliper
Do you want to go to 15" wheels? If not choose the 250 mm rotors.
Posted on: 2015/6/30 5:55
not having much lucky up loading pics, the only site I have trouble with frustrating
Posted on: 2015/6/30 7:09
Then upload to another site, and link to the photo here.
The main problem is the size of the photo. We can upload a 1.3 megapixel photo, but the site won't auto-resize larger photos. It briefly shows a message stating what the problem is, but if you aren't watching you probably missed it.
Posted on: 2015/6/30 9:00
Posted on: 2015/6/30 12:23
Good pic. I'd guess that is the 250 mm caliper.
The two calipers look very similar. It's the factory bracket that differs the most. You'll need it for the conversion, in addition to the custom adapter.
Posted on: 2015/6/30 22:08
hey lads
I'm Using S13 front calliper's & rear R31 skyline's,(all callipers have had new seals kits)
plus using Maddat's booster master cylinder,
ive blead the #OOPS# out of them by using vacuum pump....but pedal STILL goes to the freggn floor?, got me bugged... any thought's I could try or do
Posted on: 2017/4/22 13:00
im facing the same issue too..
front : vanette c22 capilers
rear : mitsubishi lancer calipers
m/pump&booster : silvia s14.
the pedal travel to almost touch the floor and soft. but managed to drive daily.
Posted on: 2017/4/23 9:24
