Sr20de+t engineering in vic
From melbourne
Hi i have a 120y which i am doing body work on at the moment and i have just got a sr20de for dirt cheap and i want to put it in the 120y
I have been reading that you can get it engineered in victoria if its N/A but if i was to turbo it will it be possible to do?
Has anyone got a turbo sr engineered in vic?
Any help/info and contacts of engineers would be great
Thanks
Posted on: 2015/7/3 11:45
Re: Sr20de+t engineering in vic
From Goulburn NSW
I don't know about vic rules but u can only do ca18det in nsw.
Posted on: 2015/7/4 2:05
Used to be possible to get a modification certificate but now it's National Code of Practice.
NCOP engine section
ENGINE CAPACITY
All vehicles originally weighing less than 800 kg: Original mass (kg) x 3.0 = max. capacity in CCs. Turbo/Supercharged: Original mass (kg) x 2.5.
730 x 2.5 = 1825 cc maximum
You may still be able ICV it, for example, put a truck chassis under the 1200.
Posted on: 2015/7/4 2:43
If you see anges sr20de race car you might not want a det
Posted on: 2015/7/4 3:25
Yeah anges car is fast but turbo is FUN 😝
But if daily duties involved just go n/a
Posted on: 2015/7/4 6:17
Car free
From melbourne
What if i get it engineered as a sr20de then turbo it later on chances of getting into trouble would be alot less? Bad idea?
Does a turbo system have to be engineered ?
alot of people add turboes to NA engines without engineering is this legal with no engineering or is it just something people dont bother doing?
Thanks
Posted on: 2015/7/4 9:57
You can, but you still should engineer a turbo.
Posted on: 2015/7/4 10:51
Car free
From melbourne
So if i was to turbo a A12 engine the legal way to do it would be to get it engineered?. But i guess most people dont bother?
This wont be my daily but i dont want to get refused insurance claim if im in a accident over a turbo.
Thanks
Posted on: 2015/7/4 14:39
If turbo is fitted then yes you should engineer it even a little a12
Posted on: 2015/7/5 5:56
Car free
By law you need to engineer turbo conversion.
Contact a Vass engineer to see about your plans
Posted on: 2015/7/5 6:25
