a12 turbo
From Sydney NSW
hey all, have got all my turbo stuff ready to go in etc,
just having trouble finding a diagram of exactly what to weld on the dizzy, yes i know it is the mechanical advance to stop detonation, just looking for a pic or diagram of exactly how much to weld etc, don't want the dizzy to advance 30 degrees and mr big bang happen.
thanks, will post up build sometime, currently repairing body work, has mild cam and weber carb,locked diff, just want a little bit more power for hektic skids.
thanks
Posted on: 2015/7/10 8:15
Re: a12 turbo
See these slots? Unbolt the part, then weld the slot to limit how long the slot is. Shorter slots mean very little mechanical advance. You could weld it so the pins barely fit in (no advance), but it is beneficial to have some advance on a turbo.
Pins on the fly-out governer weights fit into the slots
Posted on: 2015/7/10 8:38
Re: a12 turbo
Here's a good picture showing the slots JB-Welded to severely limit mechanical advance.
Posted on: 2015/7/10 9:21
Re: a12 turbo
From Sydney NSW
Ah awesome I thought it might have been that, thanks for the pics and explanation, turbo is only a t25 and have a weber (turbo) hat coming, then just to rejet the carby, not after massive power hoping to see around the 50kw mark at the wheels, roughly a 20/30% increase, only thing, where do I take the oil supply from to supply the turbo? And the coolant? Hmm
Posted on: 2015/7/10 13:46
™ ╣ ♠♥..$qü!rt..♣♦ ╠ ™
The only way to go 'round a corner is sidewayz!
'69 1000 resto
'71 1200 daily
s14 s2
Re: a12 turbo
From Sydney NSW
Typo before turbo is a t15, small but should be fine for this little 1.2, it's a gt1544 to be exact, only thing I'm having problem is with it I can't find a dump pipe to suit. :( can get the flange just can't find remade dump,
Posted on: 2015/7/12 0:55
'69 1000 resto
'71 1200 daily
s14 s2
