« 1 2 (3)
Re: A14 help please
140/140 is used by weber as baseline jetting for the 32/36. Same baseline is used for stock or worked engines. It's only a beginning as tuning is an iterative process, repeatedly changing the jetting until the ratio gets more and more fine tuned.
Yes, I mean the main jets. But the air jets are just as important as they control the air/fuel ratio in combination with the main fuel jets.
Weber Baseline Tuning - A14
Carb: 32/36 DGV/DGEV/DGAV
Part #: 22680.033B
Venturis: 26/27
Auxiliary venturis: 3.5/3.5
Main jets: 140/140
Emulsion tubes: F50/F50
Air correction jets: 170/160
Idle jets: 60/50
Pump jet: 50
Needle valve: 2.00
I'm not sure how turbo usage affects the jetting, aside from wanting to run the a/f ratio on the rich side.
Posted on: 2015/8/10 12:00
Re: A14 help please
From Penrith, Sydney, NSW
Alright thanks mate. The spare weber i have was supposedly jetted for A14 but never used it. Will give it a go.
Thanks again.
Trav
Posted on: 2015/8/10 12:20
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
Re: A14 help please
Right you were dave, except it wasnt a bigger fuel jet but a deliberately blocked secondary air jet. I rejetted with 127/140 for fuel and 165/160 for air and is running well. Prob still needs a slightly smaller secondary air jet to run perfect but happy enough for now.
Cheers
Trav
Posted on: 2015/8/21 21:28
« 1 2 (3)
