« 1 2 (3)
Re: 510 vs 910 front brake
I believe that is an aftermarket add-on.
The B310 proportion valve is built into the Splitter and is called "NP-Valve". However that is usually mounted on the firewall, so your car may have been modified.
Regarding the add-on, I would remove it so that it does not interfere with your factory braking system.
jpg  Splitter.jpg (152.57 KB)
174_55c3b0d96d27e.jpg 450X800 px
Posted on: 2015/8/6 20:09
on double-checking, that circled item looks like the stock NP-Valve in the stock location.
NP-Valve is not adjustable, it is automatic for varying loads. So the car will not lock up the brakes when empty or full load. B110 did not have this, but most B310 do.
Posted on: 2015/8/6 21:40
Hi mate thanks for the reply...
I was told from the previous owner, the master cylinder and servo are from non abs Silvia s14....
Posted on: 2015/8/7 15:02
Ah, that makes sense. The S14 has that big extension on the master cylinder
S14 Master Cylinder
So it looks like you're all set, all looks good.
Posted on: 2015/8/7 22:38
the big adopter is actually a pressure regulator, which limits the rear bake pressure. i got this info while surfing internet and i did open mine to look inside it. and yes it is regulator.
jpg  WP_20150824_004.jpg (104.41 KB)
17554_55daa0a652165.jpg 569X320 px
Posted on: 2015/8/24 5:45
some photos...
did electric fan conversion with Thermoswitch. fan from toyota Wish.
jpg  WP_20150817_016.jpg (166.69 KB)
17554_55daa3209168b.jpg 711X400 px
jpg  WP_20150817_017.jpg (173.45 KB)
17554_55daa329aadd3.jpg 711X400 px
jpg  WP_20150824_003.jpg (107.00 KB)
17554_55daa37e9dd40.jpg 320X569 px
Posted on: 2015/8/24 5:54
« 1 2 (3)
