WELD DRAGLITES INFO?
Not too shy to talk
Hey everyone,
I am thinking of putting on a set of Weld Draglites on my 1200 ute. They are pretty sweet wheel and I was just wondering what size is a good fit i.e. doesn't rub on the guards and doesn't stick out beyond the guards? The guards on my ute haven't been flared. From I can gather a lot of people put 15x5 or 5.5 on the fronts and 15x6 or 7 on the rears. I am currently running a set of Superlites 15x6 4/114.3P24.
Cheers
Posted on: 2015/9/1 1:38
Re: WELD DRAGLITES INFO?
15x6 should work well, depending on the tyres you fit. Maybe +5 offset and narrow 175-width front and rear: +20 offset 195-width rear. Probably need to roll the guards on the front. Plenty of room in the back.
15x6 +5 will fit all around but it probably requires rolling the rear guards to fit 195-width tires in the rear.
Posted on: 2015/9/1 3:37
175/60R15
* is 23.3" in diameter
195/50R15
* is 22.7" in diameter
So they won't quite fill the wheel wells unless the 1200 is lowered. Both sizes are readily available in USA.
If the wheel well corner is modified, the 195/50R15 will fit the front too. See Modifying Foot Well.
Posted on: 2015/9/1 5:36
