WTB: twin Hitachi throttle shaft
Hi all, I'm chasing a throttle shaft for twin Hitachis. They carbs look to be off an A12T, so I think I need PN: 16361-H5702. The original has been modified so as to be unusable! Cheers, Stewart
Posted on: 2015/9/14 1:25
Re: WTB: twin Hitachi throttle shaft
From Freo
PM'd Stewbacca
Posted on: 2015/9/15 3:27
A15 PSI Project Motor
'72 CB750k,
From Melbourne, Australia
im chasing the throttle linkage (joins the two carby's and connects the accelerator cable)
i'm not sure if that's the same part referred to above, but if you dundee or someone else has that part i would be keen.
Posted on: 2015/9/15 5:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Freo
I think we are all chasing the same bit....
it's unfortunate the linkage drops out when you take the carbs/manifold off, and gets misplaced,
I have been hunting for years...
and 1200rallycar has been too,
Wanted
also wanted
other wanted
Posted on: 2015/9/15 23:30
Edited by Dundee1000 on 2015/9/15 23:46:37
'72 CB750k,
oh ok, yeah
i've been thinking of modifying an L-series one to suit, but its not that simple to do, probably a day of stuffing around cutting welding measuring twice
Posted on: 2015/9/16 1:08
1200 Coupe Rallycar
Throttle Shaft goes through the carby and the throttle blades bolt to it.
Probably the same as L-series.
#1 in this diagram 16122 SHAFT ASS'Y-throttle
16361 AUXILIARY SHAFT ASS'Y-throttle goes between the carburetors. Very different from L-series which doesn't use a throttle cable.
Posted on: 2015/9/16 1:32
A12 GX - only has Cable receptor
A12T - has adjustment screw
Posted on: 2015/9/16 1:39
Thanks for the feedback guys. It looks like fabrication of a new one will be the answer.
Posted on: 2015/9/16 2:16
yeah, i think an l-series one is a good start, but it doesnt have a cable attachment and is too long, looks like you need to attach a cable attachment (probably from stock a-series single carby) and also cut the linkage shorter and rotate it somewhat when you join it back together
i havent attempted it yet or done the fine measurements of the ball ends etc to make sure though
Posted on: 2015/9/16 2:39
1200 Coupe Rallycar
From Freo
it's a bit of mucking about, I fabbed one up on Monday,
it's not pretty, there are some weird angles going on there..
you said we could get a few made a few years ago, for $50.... are they still keen?
Posted on: 2015/9/16 9:47
'72 CB750k,
