From newcastle, NSW
It's been ages since I've been on here.........
With a heavy heart and failing health I have decided to have a clean out of all of my Datsun parts that I have accumulated over the years. I thought I would give everybody the heads up before I put them on ebay/gumtree.
Parts for sale:
T50 Celica 5-speed with Dellow conversion to suit A-series, comes with a balanced tailshaft to suit the T-50 and the yoke fits H-165 diff, I do have a clutch kit that was purchased from Dellow, brass shim is included, as well as clutch plate, I do have an A-series pressure plate that can be used, but the steel thrust bearing is missing, easy enough to get though.
Datsun 1000 2-door sedan no engine or gearbox installed, c/w A14- complete but in pieces, late model 'smooth case' 4-speed and tail shaft. I installed a H165 diff...... I intended to race it but life seemed to get in the way, as it always does!! it is rust free, apart for a tiny spot in the lower left hand corner of the passenger side door, body has a few dings in it, but easily fixable!! it has complete interior except for the carpet, also comes with various parts, I do have a bonnet but it has a hole cut in it to suit the turbo set up I had in it. It would make an ideal father son project, especially if you like jigsaw puzzles.
Blow-through A-series turbo set up, using 350 Holley, even have the dump pipe, c/w all hoses and clamps.
A-15 engine, complete apart from the inlet manifold, which was used apart of a turbo set-up.
Turbo manifold to suit A-series.
A-14 turbo motor, in pieces........ has all the gear to run a decent amount of boost, deep dish pistons etc.
Front air dam and bobtail to suit 1200 coupe, came off my blue coupe, air dam has a split, but can be easily fixed.
I have various other odds and sods, all of which I'll add as I go through them. I haven't put any prices up as yet just putting the feelers out to see if anyone is interested in these items. Pics will follow, probably have to go through photobucket or something similar. Send me a PM if interested and we'll work something out.
Posted on: 2015/9/18 6:06
