SPEEDO DRIVES
From Nyngan, nsw Australia
hi fulla's where can I buy a Datsun 1200/ca18det mechanical speedo gear drives (top one) 22 teeth
Posted on: 2015/10/20 0:39
living is good,.....
Re: SPEEDO DRIVES
Wrecking yard -- 1980s Nissan such as D21, S12 or Bluebird. I would get the 23 tooth version, unless you are using tyres as large as the S13 uses.
Nissan part numbers
* 32703-86402 22T
* 32703-86403 23T
* 32707-78000 Sleeve Assy for 16-19T gears
* 32707-66300 Sleeve Assy for 20-23T gears
https://www.courtesyparts.com/oe-nissan/3270386403
Posted on: 2015/10/21 1:00
Re: SPEEDO DRIVES
using S13 gearbox, thanks for that, running 14" wheels at the moment, near future 16"
Posted on: 2015/10/24 19:07
Re: SPEEDO DRIVES
The gear is only $20, so you can change it later to adjust the speedometer readout.
Posted on: 2015/10/24 23:26
