WTB 1200/120y hubs
Not too shy to talk
Unfortunately after giving my struts to a workshop they have lost my hubs
Posted on: 2015/11/6 9:45
Re: WTB 1200/120y hubs
From Armidale N.S.W
Can probably help but need to confirm. I'm sure theirs 2 types of 120y struts one same as 1200 and other are in there own league the latter have a larger/thicker stub axle and therefore have a bigger nut on them.
Posted on: 2015/11/6 10:13
73 1200 wagon SOLD
Not too shy to talk
Hey mate, i should be able to measure the stubs tomorrow. i originally had standard 1200 ute hubs on 120y struts if that helps.
Posted on: 2015/11/6 11:08
"ute hubs" = 1200 drum-brake hubs. They are 5mm different than disc-brake hubs
From 1976, the ute used H74 hubs, which were introduced in the 120Y production October 1975. Prior to that the 120Y used the same hubs as Datsun 1200.
Posted on: 2015/11/6 23:08
Not too shy to talk
ok, i have 120y struts which i converted to s13 brakes and i used the 1200 drum hubs
whats the 5mm difference with drum brake hubs and disc hubs? track width or hub diameter?
Posted on: 2015/11/7 0:35
the 5mm difference disc vs drum hubs
Do you need early 1200 drum hubs? Or late 1200 drum hubs? They changed October 1975. Both are low height but take different bearings.
Remove and measure the hub bearing grease cap?
Measure inside lip
43mm - early
40mm - late
Posted on: 2015/11/7 0:53
Not too shy to talk
The workshop lost the hubs, bearings, bearing cap. Are the stub shafts the same size? This is really frustrating must remember to take photos of parts before handing them over
Posted on: 2015/11/7 3:26
The spindles (stub axle shafts) are welded to the bottom of the strut tubes.
There are two different ones: Early 120Y and late 120Y. Each has a different size spindle and thus takes a different hub. I would examine the strut tubes for the Nissan part number.
Posted on: 2015/11/7 4:25
early struts have an H50/H51 part number.
late struts have a H75 part number. The spindle is slightly larger (uses 610/180B bearings).
Posted on: 2015/11/7 5:24
Not too shy to talk
Is the part number near the top of the strut tube, I think it may be gone due to converting to coilover
Posted on: 2015/11/11 9:22
