how to disconnect steel break tude at the caliper
From Sydney, Australia
Hi Guys,
I am trying to disconnect the break tube from the Calliper end however the nut is not coming loose. I have used WD40 and have now nearly stripped the head :(
Any suggestion?
jpg  Capture.JPG (88.60 KB)
18758_56480789b6154.jpg 646X675 px
Posted on: 2015/11/15 4:18
Re: how to disconnect steel break tude at the caliper
Gotta have the right attitude. Use vice-grips and it will come off.
This is the tool to prevent damage to the flare nut. 10 mm:
Posted on: 2015/11/15 5:11
thanks dd :)
Finally managed to get it loose with vice grip.
Posted on: 2015/11/15 5:55
From Sydney Australia
If all else fails it will destroy the nut but whar is known as a "Spring Loaded Speed Wrench" will get them undone because it uses a swivel spring loaded design and the harder something is to undo the tighter it grips.
Posted on: 2015/11/20 11:40
