We've never seen photos of twin Nikkis -- can you post a photo? Most 1600s here came with single Nikki. Our twin carb engines came with twin Hitachis.
The 280ZX swap is a simple, well-documented swap. See photos and overview at
280ZX Strut Swap. It is written for 1200 (and 120Y) so differs a bit compared to the L16-powered B210.
I would like to replace the front strut assemblies with either Skyline or Stanza parts. Anyone got any ideas as to which will fit with least pain and any other tips?
The Stanza swap doesn't gain you much. The Stanza brakes are a bit better, but the struts are nearly same as what you have now (tall 2.0" struts).
Skyline gives you many choices. R30/R31 has been done, but it's not a great swap, requires a ring spacer and reportedly has positive camber change (instead of the desired negative camber).
S13/S14 has been done, too. See
Strut swaps.
I'm not sure how the GB210/610 upgrades to newer struts are done. Might be worth asking the 1600 fans. The only upgrade I'm familiar with for the 1600 is the 280ZX struts/brakes.
