Sunny b310 suspension/diff
Hi all
wondering what rear suspension/diff setups people have in their sunny/b310
Also, I have s13 front coilovers and my swaybar holes don't line up anymore.. Is it okay to just drill new holes in the lcas?
Posted on: 2015/11/17 7:21
Re: Sunny b310 suspension/diff
You have S13 front coilovers. Which LCAs are you using?
Using the stock B310 LCAs allows the use of the stock swaybars
Posted on: 2015/11/17 7:51
I'm using the s13 lcas, in hindsight I should have used b310 as my track wouldnt be so much, wouldn't have needed different Castor rods and wouldn't have needed to modify the crossmember or make the washers
Do you know if it's possible for me to redrill holes
Posted on: 2015/11/17 23:57
Sure it's possible. It's only one hole per side.
Posted on: 2015/11/18 0:31
Here's the location of the swaybar link hole. It's important to get it in the correct location because the links will bend if the hole is off-center in relation to the bar ends.
jpg  LCA_swaybar_link.jpg (71.02 KB)
174_564be093a2945.jpg 560X384 px
Posted on: 2015/11/18 2:33
