Wanted - A NON working 1200 Tacho!!!!
From Mordialloc Victoria 3195
Yes that's correct - I want a broken one.
The reason being is , I have a good spare but I'm having trouble bringing myself to pulling the guts out of it so I can convert it to one that will work with the output from a fuel injection ECU, thus retaining the stock look from the front.
Will swap with my working one with some extra dollars
Posted on: 2016/1/12 11:00
keep it simple
Re: Wanted - A NON working 1200 Tacho!!!!
No mods are needed if you have a factory B110 tachometer (the kind with the loop of wire on the back).
Works with ECUs and works with from 1 to 4 coil packs
However, if you connect the ECU Tach signal wire to it, it will put 12V into your ECU, potentially damaging it. So don't wire it that way. No need to use the ECU Tach signal at all.
Posted on: 2016/1/13 0:37
Thanks DD will give it a go
Posted on: 2016/1/13 0:43
keep it simple
Well whataya know - It works a treat. Thanks again DD
Posted on: 2016/1/13 1:39
keep it simple
