« 1 2 3 (4)
Re: EGI What are these things on the manifold and which ones are needed?
From Sydney, NSW
With the water temp sensor etc I see in this pic http://datsun1200.com/modules/myalbum/photo.php?lid=21837 that there's a water hose in from the front of the head.. Just wondering where the water exits or it doesn't?
Posted on: 2016/1/21 14:28
It's just like the GX manifold
Water goes in the manifold via the hose and exits through the small holes in the head.
A14/A15 wet port cylinder head
Posted on: 2016/1/21 21:04
From Sydney, NSW
Ah so that's what the holes are for in the front! Any advantages to running a wet vs dry head?
Posted on: 2016/1/21 21:17
The question is not about wet vs dry head, it's about running a hotspot vs no hotspot. HP drops at low airflow, and runs less smoothly, if the engine has no hotspot as sikyne recently found
There are two common methods:
* Dry manifold with Heat Riser
* Water-heated inlet manifold
The choice of which to use is determined by the inlet manifold -- it either bolts to the exhaust manifold, or if has provision for water ducting
Some racers run without hotspot. Works OK as they normally only run full-throttle
Posted on: 2016/1/21 22:13
From Sydney, NSW
so your advice would be to run the water to create a hot spot?
Posted on: 2016/1/21 22:19
It depends:
* If you are going to be racing the engine, no street driving, tap & plug the holes in the cylinder head, the remove the hose fitting from the manifold and plug the hole
* For a street engine, yes I recommend connecting the hose. 1 hose, two hose clamps. Done.
Posted on: 2016/1/21 23:06
From Sydney, NSW
Thanks again David..
Posted on: 2016/1/21 23:52
« 1 2 3 (4)
