mods to Std Hitachi carb
Played around with jets this weekend and managed to get it pretty good. I suspect a large amount of beginners luck involved but it runs between 14 and 15:1 normally, 13:1 ish when accelerating hard and about 15.5-16 when cruising at about 110kmh.
This is on my 1527cc A15 with a camtech 621 cam and 10.8: CR.
I know that the Carb is the bottleneck, and i have some A14T carbs to put on it when i have time, but are there any easy mods which can be done to get more out of the stock Hitachi ?
remove choke butterfly and shaft ? i never use it ..
ram pipe?
i have a K&N filter already
Posted on: 2016/1/25 4:24
Re: mods to Std Hitachi carb
From Melbourne, Australia
seriously dont bother, way too restrictive at high rpm, just do the carb swap ASAP
play with electronic distributor, thermo fan and extractors for better results
Posted on: 2016/1/25 4:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
OK thanks, have thermo fan and extractors already, and programmable ignition next on my plan...
Posted on: 2016/1/25 4:54
