water suction pipe
im about to replace my suction pipe with a new one. currently its an A15 and has the original suction pipe with the single curved up outlet.
i will be running twin webers eventually and want to know do i need that additional outlet or can i just get a straight pipe?
thanks
Posted on: 2016/1/26 18:58
Re: water suction pipe
The small inlet is for
* Heater hose
or
* water-heated manifold
As long as you have another way to supply those, a straight pipe is OK
Datsun 1200 B110 used a straight pipe
Posted on: 2016/1/26 21:47
great thanks for that.
Posted on: 2016/1/26 21:53
with the single curved outlet my A15 has it alot closer to the block than the others pictured in the wiki. i cant find the part number for the closer one.
does anybody know what its from. my A15 came out of a b310 but the nissan drawings show it be be the same as the a12 even though the numbers are different.
Posted on: 2016/1/26 22:56
Picture?
I know of at least five different types. They all fit the same engines, but vary with either None, One, or Two small inlets. And in various positions.
Posted on: 2016/1/26 23:20
as you can see the curved pipe is close to the block
jpg  bcoupe2.jpg (66.55 KB)
17392_56a80226829e1.jpg 480X360 px
Posted on: 2016/1/26 23:32
That's the heater hose connection. Tap the pipe out, rotate it 30 degrees and put it back in
Posted on: 2016/1/26 23:46
compared to this the heater hose connection is alot further from the block. im trying to replace my existing with the same one which is the same as the first pic.
jpg  index.jpg (8.90 KB)
17392_56a806705fe64.jpg 259X194 px
Posted on: 2016/1/26 23:52
so no one knows the part number of the suction pipe in the first pic? or what model its from?
Posted on: 2016/1/28 2:38
the pipe in the first pic is the original B110 style (1970-1973 Datsun 1200)
Nissan part number 21045-18000
Also was used by Datsun 1000
Posted on: 2016/1/28 3:12
