Coolant flow
Not too shy to talk
From Adelaide
Anyone know where I can find a some diagrams of coolant flow/direction?
I plan to put H89 head and stock manifold onto an A12 block.
I have noticed between my A12s they have different pipes pressed into the block. I assume for different manifolds etc.
I'm guessing the front pipe goes to the radiator and also heater, the rear pipe goes to the mainfold and on the A12 head the fitting at the back of the head goes to the heater.
What about the H89 head which doesn't have a pipe/fitting to go to the heater and instead a temp sensor? Has someone put the sensor in there when it shouldn't be?
Posted on: 2016/2/3 10:57
Re: Coolant flow
The pipe at the back end of the block is the crankcase breather.
Dont put coolant into it !
My H89 head had a fitting for a heater but it had been crimped shut. I think by the factory as i have seen others done in exactly the same way.
Heaters not required in Thailand..
Posted on: 2016/2/3 11:02
Re: Coolant flow
The front pipe is the Suction Pipe, it pulls coolant from the radiator.
Some Suction Pipes have one or two small fittings
* heater return (B110s have this built into the lower radiator hose)
* water-heated manifold return
H89 head is identical to the A12 head as far as coolant flow and heater. The only fitting either have for the heater is the rear tap. The rear heater tap can be plugged, with no ill effect on the cooling system
Posted on: 2016/2/3 11:06
Re: Coolant flow
Here's the Factory Service Manual coolant flow diagram for standard B110
Note the suction pipe is the simple one (no small fittings), and the heater returns to the lower radiator hose Tee
Here's the 1980-1985 Datsun 1200 with heater return in the Pipe
Posted on: 2016/2/3 11:13
Re: Coolant flow
Here is the H89 manifold water return. These were used with 2-fitting Suction Pipes (1 for the heater return, 1 for the manifold return)
Arrow pointing to the water return
jpg  B310 A14 inmani bottom.jpg (48.20 KB)
174_56b1e9234ee34.jpg 600X450 px
jpg  B310 A14 inmani ports.jpg (29.43 KB)
174_56b1e95889c47.jpg 600X288 px
jpg  B310 A14 inmani top.jpg (36.48 KB)
174_56b1e963ce25c.jpg 600X450 px
Posted on: 2016/2/3 11:49
Re: Coolant flow
Not too shy to talk
From Adelaide
Thanks for all that ddgonzal.
So am I right to say the temp sensor in the back of my H89 head should be a fitting and supply the heater?
What about the pipe on the side of the block to the rear? Where does that go to?
Posted on: 2016/2/3 12:00
Re: Coolant flow
Not too shy to talk
From Adelaide
Just worked it out :)
Posted on: 2016/2/3 12:01
Re: Coolant flow
Never seen a temp switch in the back of the cylinder head, in any case you can unscrew it and reconnect the heater hose
Some heads had a temp switch on the manifold side at the rear for emission controls
For a temp gauge you can fit the sender anywhere on the head it will fit
For a thermo fan, the switch should be fitted outside the head either in the radiator or radiator hose
Posted on: 2016/2/4 0:58
