Ok so I'll continue with the build update. Today was a rough day. I dedicated the whole day to the build but seemed like I got no where. The cold weather did not help. Needed a heater in the garage to battle the cold.
I bought some decent jack stands about 3 weeks ago. In fact this is the second go around since the first ones I bought from Jegs were defective. Good thing I checked first before using them. They gave me a refund and actually paid for Fedex to come take them back for safety testing. The second pair of stands (as pictured) are from Northern Tool company and they have a safety pin to put in the side, to help me get over the jitters of having the jacks fail again. However they don't have a clevis pin to help stop the safety pin from falling out.
Ok the build.
First thing I did was get the ute up on 4 stands, take the wheels off, and try to get it as dead level as I could.
I want to see how far I need to raise the transmission to get the engine and transmission sitting level. What is the best way to do this? I tried with a four foot level to get the ute straight by checking the bottom of the sill panels (under the doors).
Even with the ute approximately level, the engine and transmission are sitting sloped a little backward - see the photo looking at the engine bay from the side. I jacked up the transmission as far as I could until the clutch fork hit the body at the top of the tunnel and it still seems off. Anyone know why? Am I just being paranoid?
I did some more measurements on the rear axle assembly to try and finally confirm that the diff is in fact H165.
Tube diameter varied from 61 to 62mm.
Spacing on the diff housing mounting bolts is 73.65mm
Strut assembly painted. Gold paint. Calipers are blue. Blue and gold is a good combo.
After I struggled with the jacks and leveling I decided to hook up the clutch cable. This way I can get all the stuff under the dash situated before I put the dash in. I replaced the clutch fork rubber boot as it was completely ruined. As I was down under the ute replacing the rubber and getting the cable attached, I noticed the wiring on the reverse light switch was looking a bit worse for the wear.
I had a closer look and it seems like the switch had a meltdown. I think its safe to say I need a replacement. Anyone know where to get one. Are any switches interchangeable with the 60a 5 speed?
Hooked up the speedo cable to the transmission and routed the cable back to the steering wheel area. Seems way too long but we will see.
Also re-loomed the lower engine harness and installed it. Started to tidy up the engine bay wiring in preparation for final wiring assembly.
Replaced the resistor with a brand new unit.
Ok lastly. In the photo of the leaf springs, where the bump stop hits the frame, what the heck are the 4 screw/bolt holes for? Am I missing a part here?
