need some help
i just got me a electronic distributor what is a good coil to go with this conversion?
is a high output msd coil a bad idea, would a stock skyline coil be better
thanks, paty
Posted on: 2016/2/1 6:55
Re: need some help
From Armidale N.S.W
You can buy a good quality Coil that fits straight into the old coil bracket. It looks exactly like your old coil but its to suit electronic dizzy. I got one when i fitted electronic dizzy to my A14 ute. Supacheap $60.
Posted on: 2016/2/1 7:26
73 1200 wagon SOLD
Re: need some help
Stock Skyline electronic ignition coil will work, and is as powerful as an MSD Blaster 2
Posted on: 2016/2/1 7:33
Re: need some help
i have setup my electronic distributor what gap should i use, do i need a nigger alternator to support? i am running a 30amp
Posted on: 2016/3/11 12:16
Re: need some help
35A alternator has no problems with EI. 30A is a problem even with points ignition, meaning if the headlights, wipers and heater fan are all on it may not be charging fully
You can use the standard sparkplug gap of 0.035"/0.9mm. Whether you can use a larger gap depends on the type of EI distributor you have. What ya got installed?
Posted on: 2016/3/12 3:57
Re: need some help
got a new alternator running :). i just put in a push start instead of the key barrel, i can drive the car but i have no indicators.... any ideas why?
Posted on: 2016/3/13 9:18
Re: need some help
push start works too unless it is uphill
Indicators/Turn Signals (Flashers) work off the main Fuse Box fuse H marked 'HORN/STOP/HAZARD'
I would first check to see if there is 12V on both sides of the fuse
1. Turn ignition to ON
2. Pull Indicator lever to left side
3. Check the voltage
Posted on: 2016/3/13 21:24
Re: need some help
sorry its a button start with a relay not a push start i apologize, i think one of the wires burnt up under the dash that goes to the key barrel, seeming i have the toggle switch and button start
it has no accesorries and the battery doesnt charge any ideas? there was a wire that burnt up and i cant figure out where it goes you might know , mechanic from work said it was
EDITED :: i wired the BW wire to the negitive side of coil alternator is charging other stuff is still not working positive is on the toggle switch acc to the positive on coil am i doing something wrong?
p.s- you have helped me tonnes ddgonzal i like the info really helps
Posted on: 2016/3/16 6:00
Edited by patydaty on 2016/3/16 7:30:59
Re: need some help
The original ignition switch only has four wires, so it's not complicated at all
The most important thing is to make sure the IGN SWITCH (or your toggle switch) b/w wire feeds the Fuse Box, because almost everything works off the Fuse Box
WHITE: 12V in
B/W: IGN 12V out to Fuse Box
B/Y: STARTER 12V solenoid wire
B/R: COIL STARTER OVERRIDE
If there is an ACC wire, it should only feed the radio and OPTIONAL rear defroster, it should not feed the coil
None of these have anything to do with the indicators, which are fed by the Fuse Box
Coil Wiring:
* NEG goes to distributor
* POS goes to 1) resistor and IGN feed 2) to OVERRIDE wire
Posted on: 2016/3/16 7:52
Re: need some help
i run the BW wire to the neg of the coil and my alteernator started charging again, postive to toggleswitch-then out to positive of the coil?
not sure what the IGN feed and override wire are or go need more detail im sorry,
running alot better now tho
Posted on: 2016/3/16 9:02
