Browsing this Thread:
1 Anonymous Users
2 inch lowering blocks set |
From Brisbane
for sale
2 inch lowering block set
$30.00
will post, located in Brisbane
call or text 0400285727 justin
Posted on: 2016/3/17 6:59
Re: 2 inch lowering blocks set |
From Vic, Australia.
Do you have the longer u bolts to go with?
Posted on: 2016/3/17 10:15
From Brisbane
The u bolts are quite hard to come by and expensive for some reason, but yes I luckily kept all four of them.. they have some surface rust only.
Posted on: 2016/3/17 23:23
Apparently there's some differences in fitment from early to late Utes do you know if the u bolts will fit the early Utes? Rough idea of postage to 3241? If you think they'll fit no worries consider them sold.
Posted on: 2016/3/18 1:52
From Brisbane
The lowering blocks I have are for the coupe however I believe the early utes had identical leaf spring width of 50mm - in terms of the axle housing width I'm unsure - it may be larger as the utes had an H165 diff.
From centre to centre these bolts are 78mm wide, and from inside edge to inside edge 67mm - that may help. As long as the diff housing is smaller than 67mm in diameter they'll fit!
Posted on: 2016/3/18 4:00
From Brisbane
Sold pending payment
Posted on: 2016/3/19 20:57
