Question(s) about lightening the flywheel
From SoCal
Hello, Datto people.
So I have this A15 that I built and stuffed into an MG Midget. Running well. I am gonna pull the engine/trans for some stuff and am considering lightening the flywheel. Reason is, despite the H89 head, the 260/.425 cam and the twin HIF4 SUs it kinda revs a bit lazy. So with the engine out I am wondering if lightening the flywheel would be worth the trouble to help it rev quickly, to help with quick rev matching when downshifting? Car is only around 1600 lbs and has a 3.9 rear ratio.
Next question: the engine was balanced when I had the machine work done. Are the flywheel neutral balanced or do they have a specified imbalance?
I am wondering if I can have it lightened without messing up the engine balance or if I have to have everything rebalanced?
Posted on: 2016/4/7 6:14
1969 MG Midget, A15/60A
Re: Question(s) about lightening the flywheel
It is neutral balance, so it does not affect the shortblock balance
Yes, lighten it up. Obtain an A12 flywheel then machine it down from 21 pounds to 14 pounds
Datsun B110 Competition Tune-Up Manual
Posted on: 2016/4/7 6:24
From SoCal
OK on the 1200 flywheel, but what about the A15 flywheel, which is what I have. Can do the same or?
Posted on: 2016/4/7 20:26
You can do similar, it will be heavier as it is thicker to start with
Posted on: 2016/4/7 23:01
