(1) 2 3 »
Wiring help! Swapped a14 into 1200
I need some pictures of a a14 swap into a 1200. Basically I need pictures of the wires that go to the started and alternator. I've extended the wires to the alternator. Just need to see where everything else goes. Also the a14 I swapped in has electronic ignition.
Posted on: 2016/4/30 3:31
Re: Wiring help! Swapped a14 into 1200
The starter is exactly the same and in the same location. So the original 1200 wires can be used unmodified
Battery Positive wire goes directly to the starter
Battery Ground wire
Starter just has two wires:
* Big wire: battery '+' terminal
* Small Black/Yellow wire: solenoid small terminal
On automatic cars, the starter 'S' wire (small wire) goes through the "Neutral Switch" (Inhibitor Switch).
Posted on: 2016/4/30 4:14
If you need help with the has electronic ignition wiring, let us know which kind of has electronic ignition it has
Here is some more Starter wiring photos:
+ main battery positive cable
S Start wire from harness (Black w/Yellow stripe)
Posted on: 2016/4/30 4:54
Ok I see the black and yellow wire. What are the other two that come out of the harness in the same place? There is three wires.
Dunno, my 1200 didn't have that. What year and model is your 1200? What color are the three wires?
Posted on: 2016/4/30 5:36
Mine is a 72. There is the black and yellow wire. Then there is a black wire and a yellow one. How do I know what distributor I have? The engine is from a 78 b210 gx.
Posted on: 2016/4/30 5:48
1972 North America coupe, manual tranmission?
So there is:
* black and yellow wire
* black wire
* yellow
Trouble is ... no one has ever taken photos of the wiring ...
BY is starter solenoid
B is likely the distributor (points) wire
Y ??? ... YB is oil pressure, and YW is temp sender
Posted on: 2016/4/30 6:18
1978 HLB210 (A14 lhd B210) came factory with this distributor (remove the cap to confirm yours):
If this is what you have, it needs the ignitor box (shown in the photo at bottom) it's under the dash of the B210. The 1978 box is a high-energy type (excellent performing type)
On the body of the distributor should be the part number. Clean the grease off the side of the body and read the numbers:
Top line: Distributor Model Number (e.g. D4R). This will tell you the kind of EI it is so you can identify the cap & rotor parts. B210 electronic is D4F
Nissan part number: starts with 22100-
Posted on: 2016/4/30 6:21
Alright cool, my parts car has the black box. The first numbers on the distributor are d4f.
Posted on: 2016/4/30 6:43
Excellent, for wiring see B-210 Electronic Distributor Swap. Use the 1978 coil because it is high energy
Found this photo of an A14/A15 swap and marked it:
R battery positive cable
S (BY wire) starter solenoid
D (B wire)distributor side (points type)
leave unconnected for electronic ignition
YW temp sensor? or YB oil pressure
NOTE: If you draw power off the POS terminal (as in this photo with all the extra wires), make sure they are fused close by, as the POS cable is unfused and therefore has no anti-fire protection (see Fusible Link)
Posted on: 2016/4/30 6:56
(1) 2 3 »
