« 1 (2)
Re: Where to buy non-retractable seatbelts in older style?
It looks like SeatbeltPlanet.com wants the anchorage dimensions? The good thing is you don't need old belts to determine this -- just measure your coupe mount points
Dimension "B": from side-lower bolt to side-upper bolt
Dimension "A": from floor bolt (nearest door) to side-upper bolt
Then add 75"
jpg  belt length.jpg (27.57 KB)
174_57281775cb47e.jpg 288X464 px
Posted on: 2016/5/3 4:12
From Mordialloc Victoria 3195
DD
I dont know if it was only on Australian delivered models my mine mount directly from the base of the back window just behind the B pillar. No inertia real ( didn't go to the floor )
This was annoying because it kept slipping off my shoulder so I fitted (VW polo rear seat) retractable ones.
Yes 620mm is correct
Posted on: 2016/5/3 5:09
keep it simple
Maybe we are talking about two different things...
This is the Front belt diagram: the shaded areas are where the Front seat belts (shoulder belts) mount
Posted on: 2016/5/3 7:02
* early: on B-pillar
* late: above side glass, aft of B-pillar
Looks like some Australian coupes mounted it in a 3rd location
* below side glass
Early coupe (Japan)
Late sedan (Australia)
Early sedan (Australia)
Posted on: 2016/5/3 8:21
That top photo is of my Coupe with the VW polo Inertia reel fitted.
Originally came straight from the mount on the back window base , over the shoulder to the buckle , then over the lap to the inner sill.
Posted on: 2016/5/3 10:44
keep it simple
« 1 (2)
