« 1 2 (3)
Re: Wiring help! Swapped a14 into 1200
I still have the voltage regulator hooked up. Could that be a problem?
Posted on: 2016/5/6 1:57
That definitely causes problems!
Posted on: 2016/5/6 5:34
The 1978 USA B210 alternator has a built-in regulator. So if you use it in an older car - say a 1972 B110 or a 1977 B210 - which has an external regulator it doesn't work correctly. Apparently it won't cause permanent damage
The solution is to unplug the regulator (and leave it disconnected) then cross two wires so it will charge correctly
Posted on: 2016/5/6 8:26
What wires do I cross to make it charge correctly?
Posted on: 2016/5/6 9:37
See Post #11 of this discussion (this is Post #25)
Posted on: 2016/5/6 10:31
Ok I spliced the wires from the voltage regulator. It seems better but I still have a miss fire. I noticed when I hook up the battery there is a clicking sound even when the ignition is off. It bolts right next to the horn on the driver side. It has four wires going into it. It has red,yellow,black and blue wires. It seems to get warm when the battery is hooked up.
Posted on: 2016/5/7 2:38
Disconnect it, I think that's not a stock 1200 part
Posted on: 2016/5/7 5:08
« 1 2 (3)
