« 1 (2)
Re: Bolts/screws etc when spannering a motor together
DATSUN A12 A14 A15 Metric Engine Bolt Kit
I used the above link as a guide and went down to my local Warburtons and purchased all stainless steel items.
I got this kit all in stainless steel for $17.00.
You may as well get ARP head studs to put the head on.
As for the rest, go down to your local wreckers as ddgonzal said and scab the ones you need and clean them up on a wire wheel. Or label and bag them up as you take them from the wreckers, and go get new stainless ones for them also!
Posted on: 2016/7/20 12:03
From Sydney, NSW
Thanks ruredi! Just wondering if you have a part number for the arp head studs to suit an a15?
Posted on: 2016/7/20 12:37
I stand corrected -- Bprojects has a kit!
* Bprojects eBay: $45
* Bprojects web: kit not found
Looks like a special limited item (5 available)
Posted on: 2016/7/20 22:50
From Sydney, NSW
Is it best to use high tensile where possible or can standard 316 stainless be OK for everything except the head bolts
Posted on: 2016/7/20 22:59
ARP 202-4203
http://amazon.com/ARP-202-4203-Cylinder-Head-Stud/dp/B00I5AQPX8
Waste of money unless you will be exceeding 1 bar boost. The factory Nissan A15 head bolts are used on 2.4 liter engines so they are plenty strong. Proper preparation and every-two-year retorque prevents gasket failure
Posted on: 2016/7/20 23:03
Most of the engine bolts are not high-tensile. Of course rod/main/head bolts are
The Nissan part numbers tell you the strength:
* 0811 - low carbon steel
* 0812 - medium carbon steel
* 0813 - Alloy steel
For example, from our parts catalog
08110-61410 BOLT M6 FIXING OIL PAN
0811 is low-carbon steel
Posted on: 2016/7/20 23:10
From Sydney, NSW
Thanks David that's a super handy hint to know re the starting numbers
Posted on: 2016/7/20 23:12
I believe 316 Stainless has a lower tensile yield than even low carbon steel. Better to go with the high Datsun standards
Posted on: 2016/7/20 23:15
« 1 (2)
