Dual outlet 1200 GX exhaust manifold?
From USA
Has anyone got one of these? Were they factory installed on the twin SU equipped 1200GX's? I saw this pic in an older Nissan Motorsport catalog:
Posted on: 2004/6/20 3:01
Re: Dual outlet 1200 GX exhaust manifold?
From Little Rock, AR
I used to have one of these in really good shape, along with the front tailpipe section too. My dad sold it a few years back to some dude back in the States. From what I know they came factory on the GX models. Better than a standard exhaust manifold, but not as good as headers. There was a problem with the exhaust pipe hitting the clutch slave cylinder on a LHD car, but I'm sure it could be worked around...just the pipe that came with it curved right into the slave cyl. I havn't seen many more of these around, but if you wanted, you could run true dual exhaust with one of these, kinda pointless though (extra weight).
Posted on: 2004/6/20 5:26
look svery similat to the 3 flange a15 exhaust set up... that comes on jap spec a15 models, good for low down tourque but not as good for high rpm use, almost as good as extractors
Posted on: 2004/6/20 8:06
From Melbourne, Australia
yeah ive got a couple spare if your chasing some?
they were the GX exhaust, so yeah, they were on the same models as SU's
Posted on: 2004/6/20 8:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From campbelltown (sydney) australia
itd be easier and maybe even cheaper to buy a good set of extractors, plus they will be of more use anyways. unless ur trying to build a car as near to standard as possible.
Posted on: 2004/6/20 11:40
yeah i sold a set to a guy in finland, as he races in a historic class, it's the best factory exhaust he can get
Posted on: 2004/6/20 11:44
1200 Coupe Rallycar
From USA
Thanks for the replies guys. The reason I am interested in one of those exhaust manifolds is because in rallying, wouldn't they be more reliable than a header? I mean, don't header's get flattened when jumping a car over bumps?
Posted on: 2004/6/20 16:25
From Burbank Ca.
Not to hijack this thread, but does anybody know if this manifold is adequate for A15/mild build use?
Posted on: 2004/6/20 18:42
yes will be fine for mild a15, but if you want more hp, get extractors for higher hp in the upper rpm band. These are better for low and mid range power
Posted on: 2004/6/21 0:55
From USA
Headers make good power, but mine hang down too low and come too close to my hydraulic slave cylinder hose.
OK anyone got one of these dual outlet manifolds to sell me and are willing to send it to the US?
Posted on: 2004/9/26 3:35
