Original fuel pump rebuild kit
From melbourne
Hi just wandering if you can buy kit with all seals etc for the rebuildable fuel pumps?
If so were can i find it?
Thanks
Posted on: 2016/8/25 0:25
Re: Original fuel pump rebuild kit
Sure thing
Can buy from new-datsun-parts.com
* Pump gasket diaphragm kit $40
* Pump fuel valves $19
Or you can buy a new fuel pump for $39 on eBay
Posted on: 2016/8/25 0:58
From melbourne
Ok cool
Reason i ask is because i am putting bike carburettors on my engine and i hear the pump pressure is too high at 2.6psi and needs to be around 1 psi?
So i was thinking to open a original pump and cut the spring until i reach the 1psi and want to make sure i can get a kit for it if i need to
Does this sound like it will work? From my unteratanding the spring is what sets the pressure?
Thanks
Posted on: 2016/8/25 5:54
Rebuild kits don't come with a spring. For that I'd buy a new or used fuel pump
Yes, that sounds right. Spring pressure sets the fuel pressure. Bike carbs use gravity feed for the most part. Dunno if 1 psi is too much or not
Posted on: 2016/8/25 6:02
