Browsing this Thread:
1 Anonymous Users
Wtb late model valve spring retainers and seats |
From Sydney, NSW
Just wondering if anyone has valve spring retainers and seats from a late model head? Apparently camtech sells double springs that don't need to use the special and expensive gx retainers
Posted on: 2016/9/16 4:50
Edited by thomen on 2016/9/16 5:23:04
Re: Wtb h89 head valve spring retainers |
Registered Users Contentmaster Usermaster
H89 head uses the same valve spring retainers as A12 standard engine
If you are upgrading to dual valve springs, you will need the retainers to fit the valves * For camtech dual springs, use standard A12/H89 retainers * For Nissan GX dual springs, use A12GX retainers OR 1973-up A12/A14/A15 standard retainers
In 1973 the standard retainers were changed to match the GX design. The earlier ones had a groove on the inside for an O-ring to seal against the collets
Posted on: 2016/9/16 5:16
From Sydney, NSW
Do I use standard seats from an a12 if using camtech springs as well?
Posted on: 2016/9/16 5:20
From Sydney, NSW
Thanks again for replying David!
Posted on: 2016/9/16 5:21
