(1) 2 3 4 ... 6 »
a14egi vs 15egi
hi all..
Found one a14egi today. incomplete wiring and no computerbox no flywheel.
What is the difference between a14e and a15e?
as i can notice, the exhaust manifold, obviously the piston/block size.
how about the cam shaft? inlet manifold? throttle body?
jpg  a14e.jpg (198.18 KB)
17554_57ffc779b60dd.jpg 716X836 px
jpg  a14e1.jpg (172.47 KB)
17554_57ffc7aed4c1e.jpg 718X924 px
jpg  a14e2.jpg (142.18 KB)
17554_57ffc7b983c40.jpg 1280X719 px
Posted on: 2016/10/13 18:44
Re: a14egi vs 15egi
* Same differences as regular A14 and A15 (pistons & crank). Flywheels are same
* Cams are same (GX type, 6400 RPM peak power)
* A14E: single outlet exhaust manifold
* A15E: dual outlet exhaust manifold
* both are 92 PS @ 6000 rpm
* A14E - 11.7 kgm @ 3600 rpm (85 ft lb)
* A15E - 12.3 kgm @ 3600 rpm (89 ft lb}
You can use inexpensive aftermarket ECU, see EGI MegaSquirt
Posted on: 2016/10/14 0:19
Re: a14egi vs 15egi
Thanks Guru!
So a15e has little more torque.
The head is same like a15e and gx?
The block in my car is from a15e. So its recommended to plug in the whole a14e or just use the head into my a15e block?
Also will there be any gain if I just use the head and maintain the twin su?
Posted on: 2016/10/14 5:45
Re: a14egi vs 15egi
A14E and A15E use the same cylinder head. Not like GX, it is more like H89 but with revised ports
You have A15E block now. Which head do you have running in your car now?
Posted on: 2016/10/14 7:11
Re: a14egi vs 15egi
I'm running with h89 head. Single valve spring.
The number on the a14e head is h891.
Posted on: 2016/10/14 9:11
Re: a14egi vs 15egi
I doubt the head will make much difference, but try it and let us know ... the A14E head should have double valve springs, which is needed for the extra high RPM
Posted on: 2016/10/14 10:26
Re: a14egi vs 15egi
yes It has dual valve springs. so the difference only at high rpm?
Posted on: 2016/10/14 20:35
Re: a14egi vs 15egi
Not the only difference, but the only obvious difference
Posted on: 2016/10/14 21:19
Re: a14egi vs 15egi
worth welding?
throttle body in condition.
jpg  inlet.jpg (171.15 KB)
17554_58013df026a5e.jpg 922X519 px
jpg  inlet1.jpg (163.29 KB)
17554_58013f5d0d971.jpg 896X504 px
jpg  inlet2.jpg (166.84 KB)
17554_58013f660a21f.jpg 896X504 px
jpg  inlet3.jpg (150.41 KB)
17554_58013f9178e69.jpg 896X504 px
Posted on: 2016/10/14 21:27
Re: a14egi vs 15egi
Any advice?
Posted on: 2016/10/15 3:05
(1) 2 3 4 ... 6 »
