« 1 2 3 (4) 5 6 »
Re: a14egi vs 15egi
Wow... Looks like I need to read alot to DIY. Will do it slowly.
Posted on: 2016/10/18 16:11
Re: a14egi vs 15egi
The local shop asking MYR 300.00 (around aud 94.00) to weld the manifold.
Posted on: 2016/10/18 16:36
Re: a14egi vs 15egi
From Little Rock, AR
I have had one of these EFI intakes for about 20 years. Bought it off a Aussie 'bloke' on this form a long time ago and had so many plans to use it until I went SR20. Now I finally have another car to use it on, so I've been preparing again to do so. You can upgrade the throttle body to use a CA20 which is much bigger. The injectors are 280ZX injectors, so any upgraded injectors you can put in a 280ZX/L 28 will also drop into the A series EGI. I built a block off plate for the bottom of the intake so I don't have to use the coolant ports on the head and can get rid of a ton of extra stuff such as the EGR and such. I am working on the timing control aspect of it now, and the E15ET or E16 distributor (CAS) is the way to go. Supposedly Megasquirt 3 can work with the Nissan optical CAS as-is, but it's still considered 'experimental software'. The better bet is to swap the optical disk in the E series dizzy to the Megasquirt disk, then you can effectively control timing with any Megasquirt ECU. With the E series dizzy, you don't have to do any other crank trigger setup to control timing with Megasquirt. These intakes are legit, but prone to cracking as you can tell, so don't try to port anything much at all. I'm mostly anxious to see how much more power and gas mileage they'll get once fully tuned. I'm going to throw mine on an A15 in my B310 wagon probably about a year from now, probably using MS3, and setup for flex fuel, then maybe eventually turbo it.
Posted on: 2016/10/18 21:23
Re: a14egi vs 15egi
It was 'experimental' until the Dec. 2015 update. Now MS3 officially supports SR, RB and VG trigger wheels for CAS timing (wheels with four different length slots). E16 wheel looks like the KA and 280ZX wheels, so unknown if MS3 works with the CAS portion of these wheels (3 small slots, 1 large slot)
The old MS2 supports Nissan CAS for ignition spark timing maps and coil trigger but does not support the cam position ring.
In any case it is not needed for the A14E or A15E engine, which uses the standard points-type distributor. MegaSquirt can also use the points as an input (no CAS required)
Posted on: 2016/10/19 2:05
Re: a14egi vs 15egi
The above explanation is not fully understand. it takes time and alot of home work. :)
Thanks for the input....
BTW, the TIG welding cost of MYR 300 is acceptable? i didn't check with another other shop yet.
Posted on: 2016/10/19 7:10
Re: a14egi vs 15egi
$94 is an acceptable cost here in my country. It is always good to check with another shop
Posted on: 2016/10/19 8:40
Re: a14egi vs 15egi
From Kelmscott Western Australia
Just done egi conversion into a 1200 ute running std ecu and afm
I can say theres more grunt and smoother running
Posted on: 2016/10/22 13:08
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Re: a14egi vs 15egi
manifold washed... will clean the internal before send for welding.
jpg  fi2.jpg (152.68 KB)
17554_580d0cd616380.jpg 648X364 px
jpg  fi1.jpg (177.31 KB)
17554_580d0dc298217.jpg 830X467 px
jpg  fi.jpg (176.02 KB)
17554_580d0de33f084.jpg 776X435 px
Posted on: 2016/10/23 20:22
Re: a14egi vs 15egi
Just for sharing.
A15egi B310 fuel pump with rubber mounting.
jpg  fp rubber mounting.jpg (195.86 KB)
17554_580f7f9aa8d4e.jpg 433X787 px
jpg  fuel pump1.jpg (188.36 KB)
17554_580f81eb88af9.jpg 437X631 px
Posted on: 2016/10/25 17:01
Re: a14egi vs 15egi
From WEST AUSTRALIA
EDIT
Posted on: 2016/10/26 11:22
Edited by KULH on 2018/3/14 0:38:29
« 1 2 3 (4) 5 6 »
