Sunny B310 Front Spring rATES
From Seven Hills
Does someone know the standard front spring rate on a Sunny B310
Also can anyone advise a suitable spring rate & length for rally spec Sunny B310 using 65 mm coil overs
Thanks
Posted on: 2016/11/20 13:33
Re: Sunny B310 Front Spring rATES
standard front spring rates on a Sunny B310 are 90.7 lbs/in (AC models: 92.4 lbs/in)
"Rally Spec" -- Tarmac rally or dirt rally? For dedicated tarmac rally most guys start with 250 lbs/in
Posted on: 2016/11/21 3:29
I can help if you need, I build Coilovers and have a set ready to go. $850aud plus post
Posted on: 2016/11/21 9:31
Car free
From Seven Hills
Thanks for info.
Car planned for club use dirt circuit initially aiming to AMSAG series or similar in NSW. The dust is still in the veins, got out of the sport before I wanted to due to work commitments back in the 80's and want to have some competitive fun again.
Building struts myself (engineering/fitter background). Rallied a Group G 1600 with all the right bits in the 80's when you built "Adjustable Safari Struts" yourself. The only other option was to scam them from people with contacts with the Datsun Rally Team. No Internet with Ebay etc back then. You were doing well if you had a fax machine at home and CB radios in the Rally car and Service vehicle!
Car planned for club use dirt circuit initially aiming to AMSAG events or similar in NSW. The dust is still in the veins, got out of the sport before I wanted to due to work commitments back then and want to have some competitive fun again.
Agree 250lb would be fine for track. I had 185lb the 1600 so would expect a lower rating for the lighter front end of a Sunny running A14 & 5 speed over the heavier 1600 with L20b and 260Z 5 speed.
Posted on: 2016/11/24 13:20
