« 1 ... 3 4 5 (6) 7 »
Re: Project Avocado: 1971 B110 Coupe build - USA
Speedo illumination and tacho illumination
The other gauge illumination is completely out 100% of the time.
Posted on: 2016/12/2 22:57
Tachometer illumination lights are grounded (earthed) via the tachometer body, specifically the tab at the bottom of the tacho being bolted to the dash frame
Check for ground at the tacho case
jpg  26334.jpg (38.32 KB)
174_5841ff3be1456.jpg 600X450 px
Posted on: 2016/12/2 23:09
All your dash illumiation lights are not working? There are three illumination bulbs in the dash Cluster Gauge, two for speedo and one in center of fuel/temp gauge
Check the headlight switch
* One of the Green/Blue (GL) wire connects to the GL wire of fuse box ('PT' terminal)
Test with light switch OFF - must have 12V at one of the GL wires. If not, check the ParkTail fuse in the Fuse Box
* The other GL wire feeds the dash harness for "parking" lamp circuit
Test with light switch at 1st pull-out position (park lights). Must be 12V on both GL wires. Ditto for 2nd pull-out position (headlights)
If that tests OK, then pull the round connector off the dash, and check for 12V at the GL wire
If the GL wire here is getting 12V, then the problem is in the Cluster Gauge. Check for burned-out bulbs, bad ground, broken/burned circuit trace, or corroded lamp connections
NOTE: There are only three illumination bulbs in the dash Cluster Gauge, two for speedo and one in center of fuel/temp gauge
Posted on: 2016/12/2 23:46
Here's how to check for: Dash Light problems
Posted on: 2016/12/3 0:25
Thanks DD.
Here is a photo before installation.
Both gauges are grounded. Hopefully its just a blown bulb.
Posted on: 2016/12/3 3:31
Brake Switch wires should be both GY
In this photo one looks GL? Which would cause the dash lamps light when you step on the brake pedal
jpg  stop_wires.jpg (22.09 KB)
174_58426130cc2a5.jpg 400X300 px
Posted on: 2016/12/3 6:07
Thanks i will check this out asap. It did this even before i took the dash out. Could be a mistake by previous owner
Posted on: 2016/12/3 15:36
What should the GL wire connect to instead?
Posted on: 2016/12/3 15:37
Currently on car:
GY and GW to brake switch. Does it matter what order?
GW and GL to hazard flasher
Posted on: 2016/12/3 17:38
GL wires are illumination
GW + GL wires is Hazard flasher
GY wires are brake/stop -- that's a problem if your switch is wired to a GW
So T/S flasher unit: G + W
* L terminal: White
* B terminal: Green
jpg  North America hazards,indicators.jpg (43.35 KB)
174_58432f233433f.jpg 400X284 px
Posted on: 2016/12/3 20:46
