porting question h72/77
From socal, USA
so i won a bid on eBay for a h95(swirl port) but its eBay so i received a different part then pictured and listed a h72 head came in the mail.
upon removing the valves for a port and polish there is a huge hole/dip in each exhaust port making me believe its h77?
How can i effectively port this to be efficient as possible? do i try and tig weld it shut or do i just normaly polish it. can any explain why they would do this?
Posted on: 2016/12/5 0:57
Re: porting question h72/77
Several heads start out with an H72 casting, but then are machined into different configurations
Part Numbers H72 & H77 has a machined air passage in the head (not all H72 castings have this machined)
AIS
jpg  11041-H7763.jpg (36.06 KB)
174_584524cd0ff5b.jpg 360X344 px
Posted on: 2016/12/5 8:34
To reduce emissions without any power loss. A passive Air Injection system uses the engine exhaust pulses to draw fresh air into the port, thus continuing to burn more fully. Since no air pump is used there is no power loss
Just port normally (clean up the bowl and inside radius, cut the guides down, use 7mm guides & valves). You can weld the holes shut if you want, how much difference it would make is unknown
For more power, weld up the combustion chambers into wedge chambers and use flat top pistons. With those open chambers use Premium fuel to reduce detonation problems, then you might as well boost the Compression Ratio and use a better chamber, which will work fine with Premium. Save fuel cost too as Premium is 10% more cost but the gain is 15% economy (along with more power)
Posted on: 2016/12/5 8:55
